X Pipe Install Help
YES, definately disconnect the battery!
As for the bottom bolt. You will need a long extension and a good solid swivel to get the socket on that nut. If you haven't already, soak the nut with PB blaster or an equivalent to try and remove some of the rust from the bolt. It will make it easier to get it unbolted.
