Fox body Mustang driveshafts are around 45", IIRC. 65-66 V8 Mustangs are either 50 or 51" depending on auto or stick.
Your rearend yoke can also play a part in the overall driveline length, best to check.
My 1966 C4 and Toploader are the same length.
Where are you guys getting Al shafts shortened for $25? The only place around here that I can find that will do it wants $125.00 balanced and everything. If that includes ujoints fine but if it is just welding, come on.
Anybody know anyone in the Cleveland, OH area?
It cost me $125 to have the aluminum shaft shortened. For the stock shaft they wanted $100 to shorten. So it cost me $25 MORE to have the aluminum shaft shortened vs the stock shaft.
I think you'll have a hard time finding a shop that will do a quality job for less than $100.
I had to swap out the rear flange because the bolt pattern was different than the mustang rear I have under the car. I spent about an hour at the parts store measuring u-joints until I found 2 possibles, lucky for me one of them fit No idea what the original application was though.
I am using a flange, from a late model mustang not the Aerostar, because the rear differential is from a 95 GT. Originally the shop was supposed to only shorten the shaft but they assembled it with new u-joints and everything.
68rustang said:The only reason I spent so much time measuring at the parts store is the parts guys behind the counter can't help you find parts unless the specific application is in their computer.
We were mid 60's tuesday, I rode my motorcycle to work, and about 70 yesterday. It was sooooooooooo nice. Then this morning my truck was frozen shut
Where abouts north of Toledo? I went to engineering school at UT. I graduated from there 12/01.
Would a mid-90's Lincoln Mark 8 driveshaft (at 58") work with shortening?
Daniel
