Yobi1Kanobi
- Apr 9, 2003
- 559
- 0
- 16
140 ish, till about 5500 rpms with 3.73s I just dont recall it since I was trying to keep up with a GSX-R
as far as i am concerned noone has done that speed unless it was gps verified--speedos are way to inaccurate.
Absolutely Not true idk with gears and changed speedo gear , but my stock 3.08 GPS verified has a top of 1-2 mph difference on all speeds from 0-120 mph verified , idk anything beyond that i dont have high speed rated tires to do more, but this cars have the most acurate speedo i have ever seen on a car.
Which is why I said ~145 on the speedo.
I want to get my buddies GPS one day and see how accurate they are.
then you sir have 1 freak of a speedo.
i have personally seen speedos on $100k+ cars be off as much as 10% at 80mph--it gets worse the higher it goes. bmw even states that a 15% difference is normal and there is nothing to fix that.
Yep. when tires get worn down, that will throw the speedo off. The slightest change will throw it off.
I've had mine at about 125 on the freeway. It had plenty left but i won't take it higher than that on public roads with our crappy stock brakes. With 3.08s or 2.73's i think you could hit 175+ if you had the power, i barely break 2k rpm going ~85.
heh heh heh
just cause you have the gearing to go 175 i dont think its possible with our suspensions, we would float right off the road
