do these things work? A friend of fine is considering of getting one for his 5.0. If it works ill consider getting one for my dd which is a 98 kia sephia. They say they will add 1-2mpg? anyone ever use one of these?
NO. GO HOME.
haha J/K..but seriously they dont work
I have 3 1/2 of those on my car and 1 one my truck. Working out good for me.
Get a Tornado and hook an air compressor line to the cai, compressed air tank superchargers ftw.
Will that work?![]()
If your concerned about MPG You may want to replace: the tach gear, Replace Blinker Fluid Modulator and top off the blinker fluid,, torque the muffler bearings and install a new O-Pipe , replace the Piston Return Spring, tighten the Clutch Belt, buy premium Spark Plug Wire cleaner,INstall the new sparkless spark plugs , Get a new Engine Oil Bypass kit, and clean your horn injector.
That should about do it.
We were joking around at work about that one day, it seems it would work in theory. If I had an air tank I'd hook it up to my escort wagon and show those LS1's whats up.
Could you imagine being in the middle of a race, neck to neck, hit the compressor switch and put a car on them. The other guy would be like 'What the hell was all that noise?!!!'
Check into direct exhaust injection too.![]()
Its not like i'm trying to sandblast (err...port and polish) my engine while its running.![]()
