I don't think it would make a much of a difference. The reason is the small plastick tube from the discharge opening of the supercharger is smaller than the TB.
I logged back to back on my V1 S-trim with the stock throttlebody and the BBK 70mm (I had a powerpipe). The flow at the mass air was EXACTLY the same. Pedal feel was touchier because of the larger throttlebody but in terms of flow, no gain.
94CobraPace is referring to the plastic between the blower and the throttlebody (which the powerpipe doesn't replace unless you get the mondo bypass unit).
The powerpipe will definitely show you a difference.
Exactly, the plastic between the TB and SC. It is very small diameter, less than 3".
Power pipe is before the supercharger, replacing the 90 elbow bend.
