I'm going to be replacing the clutch this weekend. Do anyone know if company has a better seal than anyone else? This may just be a dumb question.
I've heard the Teflon-lined one from Autozone is actually a good peice to use.
. this was close to a year ago and still no leaks. I finally got my new T5 done not to long ago and that got rid of my leaky, clunky stock T5 .. now my garage floor is free of cardboard, nice, clean & dry under her So the Teflon lined one with a thin coat of permatex around the outside and let it set up over night???
There is a little "wear-in" that does take place. A lot of guys suggest to lightly sand the crank with sandpaper to roughen it up and allow the seal to wear in a new "seat"
I've also heard of seals that position the seal in a different spot so that it wears in a new location.
Also, install tools can make a difference. There is a $100 RMS instal tool...but I used a $1.99 4" PVC knock-out cap for mine i got at home depot.
Also, PCV systems can cause the RMS to blow out oil if the crankcase is pressurized. So make sure your setup is running correctly
I don't have a clear answer on this though. I haven't even started my engine yet to see if my latest install leaks or not
The teflon seals take excessive heat better and tend to last longer. I still put a thin coating of permatex black around the seal then tap it in place, this has proven to be a leak free method for me after letting it sit overnight. When I build motors I put the seal on before I torque the cap down, this has been a god send in preventing leaks...
