Mach 1 Dyno number results with new combination
gfong
26
Here are the results of the dyno tune I had done. I am trying to get low 12's or if all the stars are aligned I would like to get into the high 11's. Not sure if that will happen but will try. Best so far was 12.64 and that was with 300hp!
Dyno numbers: 362 SAE HP & 334 SAE Torque.
Mods 2003 Mach 1
Comp Cams Part#106400
Roy's Ported & Polished Lower Intake
PHP Intake Spacer
Accufab TB
SLP Longtubes
SLP Catted X pipe & SLP Catback
Steeda CAI
4.10 gears
Zoom Clutch
Zoom Aluminum FW
Dyno tuned by Alternative Auto Performance
man, thats some great numbers! its probably a lil higher cuz of the gears tho!
Thanks, not sure what you mean about the gears. The higher ratio gears usually means lower numbers. That is what I have always gone by.
No matter the gears or the numbers the car really woke up at higher rpm's and sounds great. Thanks again.
I think they're higher more so because of the cams. :p
I have stock 3.55 gears with same cams close and similar dyno numbers so I doubt gears have much effect. :shrug:
How can i get in contact with roy?? I need my intake ported and cant get ahold of naz.
Nobody can get a hold of Naz and I wouldn't bother until he sorts some personal stuff out, that's my take based on some recent drama I've read about...that being said Roy is on the M1R.
