Dyno number results with new combination
Discussion in 'Mach 1' started by gfong, Jul 7, 2009.
  1. gfong New Member
    Aug 31, 2004
    Message Count:
    29
    Here are the results of the dyno tune I had done. I am trying to get low 12's or if all the stars are aligned I would like to get into the high 11's. Not sure if that will happen but will try. Best so far was 12.64 and that was with 300hp!
    Dyno numbers: 362 SAE HP & 334 SAE Torque.
    Mods 2003 Mach 1
    Comp Cams Part#106400
    Roy's Ported & Polished Lower Intake
    PHP Intake Spacer
    Accufab TB
    SLP Longtubes
    SLP Catted X pipe & SLP Catback
    Steeda CAI
    4.10 gears
    Zoom Clutch
    Zoom Aluminum FW
    Dyno tuned by Alternative Auto Performance
  2. VtecDis New Member
    Jul 11, 2006
    Message Count:
    man, thats some great numbers! its probably a lil higher cuz of the gears tho!
  3. gfong New Member
    Aug 31, 2004
    Message Count:
    29
    Thanks, not sure what you mean about the gears. The higher ratio gears usually means lower numbers. That is what I have always gone by.
    No matter the gears or the numbers the car really woke up at higher rpm's and sounds great. Thanks again.
  4. 04machdsg New Member
    Sep 8, 2009
    Message Count:
    orlando
    How can i get in contact with roy?? I need my intake ported and cant get ahold of naz.
  5. CatmanJJ Captain Tangnet
    Feb 5, 2002
    Message Count:
    4,579
    66
    Maryland
    I think they're higher more so because of the cams. :p
    I have stock 3.55 gears with same cams close and similar dyno numbers so I doubt gears have much effect. :shrug:
    Nobody can get a hold of Naz and I wouldn't bother until he sorts some personal stuff out, that's my take based on some recent drama I've read about...that being said Roy is on the M1R.
  6. 03 Mustang gT New Member
    Jan 6, 2009
    Message Count:
    103
    seaford, New york
    gears dont effect hp they are just a torque multiplier
  7. gfong New Member
    Aug 31, 2004
    Message Count:
    29
    Thanks for the comments.
  8. 1BADAOD New Member
    May 14, 2002
    Message Count:
    37
    Good numbers!
Share This Page
