I have a 08 with a 3.73 gear and I get a lot of wheel hop. My buddy told me I needed new stronger rear bushings is that right or what do I need to eliminate the hop. My whole dashboard looks like its going to break in half Posted via Mobile Device
yep yep. lower control arms will def help, and if you wanna go all out you can add relocation brackets, an upper control arm, and a panhard bar. you shouldnt have much wheel hop at all after that
Thanks a lot guys I do beat it pretty good I do Autocross and drag racing. Are there any really good brands of choice? Alyson will be putting on the eibach sportline springs. So should I do the arms and bars first or will lowering it not affect anything.
You want your rear lower control arms to be parallel with the ground for the least amount of hop.
I did the J&M lowers purchased the upper but didnt waist my time installing. Just looked cheesey. The lowers did nothing but increase the wheel hop and the car dont hook for crap now they will be coming off and cut up may use them for a breaker bar, or throw them in the trash. I wouldn't even resell them to someone, to purchase a higher quallity LCA.
