Has anyone had this problem? Something was draining my battery so what I did was wired a tail light bulb in series with the battery to see if it would light up. It did, so I started pulling fuses. (Saw this tip on here from somebody). Second fuse I pulled was for the electric choke and the light went off. Holley says to hook the choke up to a constant 12V. The choke will draw current when the car is off right? How much should it draw? Enough to light up the tail light bulb? (Is that 3A?)
The only wire I ran was the constant 12V. To make sure it wasn't grounding out I removed it and just ran a wire straight from the choke to the starter solenoid post. Light was still on.
So does this sound like a issue with the choke or just a weak battery?
Thanks
Thanks
