Your buddy from Autozone should be able to tell you this. If he will look up the part number on a radiator out of a gt and write the part number down, then look one up for a v6 and compare part numbers.
Short answer. NO. The V8 and V6 radiators are different. I suspect the V8 is bigger or has more fins. It may even have different size inlets/outlets.
Try this trick. Go to oreillyauto.com and look up the part. Click on the compatibilty tab and look at the other models the part also fits. Only V8's are listed.
