what 5 lug conversion where i can get the bullit deep dish rims? with out the rear wheels sticking out too far?.. what size do i go? 9.5 o 10.5??? planning on doing the conversion, but a friend told me about i cant use those rims with any 5 lug... heres a pic of wat im talking about... not trying to steal thread...[/QUOTE
You need a cnversion that keeps the stock fox track out back....either 5-lug drum. Or a modified disk brake setup using 5-lug fox length axles.
Up front, the hub of the fox style rotors tends to interfere with the inside hub of the wheel. You can try using the mark 7/svo style rotors but will most likely need a spacer to make it work. At which point the front wheels will stick out more than the rears.
The best front setup is to use an sn95 front brake setup, but involves swapping out your spindles. However, if you keep the rear drums you don't need to change the master cylinder with most setups
