Current setup:
.040" over 351W block
Fully balanced rotating assembly, stock crank and rods
KB 151 pistons
Everything CC'd, ACTUAL compression came out to 10.1:1
C9OE 351W heads- stock on the intake side with 140cc port, exhaust port "hogged", looks huge next to an E7, aftermarket stainless 1.84/1.60 valves, Comp springs, 97 lbs on the seat
Stock 5.0 HO roller cam
Howard linkbar lifters
TF 1.6 roller rockers
RPM intake
Eddy 800 cfm carb
Short tubes
Full O/R exhaust
T5
3.55 gears
Made 298hp/328tq to the tires
Doing head/cam swap real soon here. Seeing as mine are basically stock, i'll be looking for ~360rwhp. Cam will be Comp XE282HR with upgraded springs as well. Can't decide on heads. Thinking TW 170s? Want max power at 6,100 rpm so I can shift at 6,500 rpm. HELP!!!
KB 151 pistons
RPM intake
Eddy 800 cfm carb
Short tubes
Full O/R exhaust
T5
3.55 gears
