Well I got a guy who says he has a 24lb c&l off his 93 cobra. I didn't want to buy it if the tube was wrong. So I emailed c&l and this is what they wrote.
The 1993 cobra vehicle has both a different computer processor and a different mass airflow sensor. The computer is programmed specifically for 24lb injectors and the ACTUAL (different) signal that the mass airflow unit that the vehicle comes with, which is as much as 23% different than a regular 89-93 Mustang 5.0. You would need to see what calibration tube is in the unit in order to determine whether or not it would need to be changed out for your application. We have no control over that tubes customers run in their cars, so without actually looking at the unit and determining what is in the unit, it is impossible for me to tell you if it will have the right calibration tube already inside of it. Worse case scenario, you will need to purchase a new (correct) calibration tube for your application...
Lee
