I am the mother of invention when it comes to using what's laying around. Don't know if its visible, but the book under the jack stand is titled "Working alone"....and comes with all kind of tricks for lifting, and handeling heavy, and long loads alone.
kind of appropriate that I use the book to hold up a long span of exhaust tubing I think.
Yes, I plan on creating a retainer ring for each raw end of the tubing to keep it from blowing off.
The mother of invention and a God to us humble men, lol.
That book could not be more appropriate! I love it!!!
You needn't humble yourself after having combos that made the power of the ones featured in your sig. I only seek a fraction of your greatness.....and I'm far from a God.
God of ground smooth welds,......Pubah of thick wall tubas,......maybe.:cool:
I'm no expert, but have read of all sorts of problems of metal fatigue when headers are wrapped in a turbo application, might want to look into this
Yep, you are absolutely correct. I have read mixed reviews, some say bad idea, others say it worked out well. Here is my insane logic:
My driveway is extremely steep, and I have had problems with my x-pipe dragging when I go up my driveway and into my level garage. I have my coil overs adjusted up just enough to prevent this. Now, I picked these headers up for $120, and put another $80 in them. I have measured the best I can, and I THINK they will clear. If they do, great. I'll rock these out for a few years, just long enough to get me through my new HCI combo. After all that expense has passed, I will look at a set of stainless or another set of ceramic coated, like my shorties now. If they don't clear, I'm sure I can get most my money back out of them.
Joe
I've always heard that too. It keeps too much heat "in" and promotes heat related metal fatigue on thin gauge stuff. Fortunately for me I used stuff that is coke bottle thick, and I do not intend to wrap the stuff that gets hot,.. I'm gonna wrap the stuff that I don't want to get hot.
Reactions: 1 users
Well,
Spent the last the few days putting the final fit on the turbo system. I got the entire system built including the hotside, and the coldside. It still needs a bunch of detail work, (finish welding, grinding, and smoothing)
As I said i would, I bought Chinese waste gates. They cost 70.00 ea. When they got here, I took them apart because I heard that they typically were full of excess debris from the machining process, with jaggedy pieces of metal just begging to snag the diaphragm.
I'm here to tell you......they were right.
Every hole that was drilled and tapped had burrs, the hole that was cut for the valve had significant flash that needed to be ground away. Now that that is done,...I left them "gutted" so I could weld w/o worrying about melting the diaphragm. I also heard that the springs were inaccurate,...and I had to check the actual rated pressure to be sure it was accurate. ( especially since I have two of them) I haven't done that yet, but this car is far from running, I'll cross that bridge when I get to it.
The rear waste gate placement pretty well means that the A/C system will definitely either have to be relocated, or eliminated. I planned on relocating the A/C lines before I even bought the turbo,..so it's just one more bump I gotta deal with.
I decided to re route the coldside under the intake,..as there was no room for the front waste gate in my original plan. By clocking the turbo in this orientation, I gives me room for the waste gate, but will most assuredly force me to cut a hole in the hood, and there may be valve cover interference issues. But again, I'm building the valve cover, so I'll try to take that into consideration when that day comes. Clearly, I got two more holes to close up during the engine bay smoothing stage.
I wanted to get this part behind me so I could start on the engine bay I got one more 3" hole to cut for the piping that comes out of the inter cooler going to the throttlebody, and my hole cutting days are done.
Reactions: 2 users
I love custom turbo piping. Gives me a chubby every time. I'm glad to see you went with dual wastegates. You have two very distinct collectors at the turbo flange, but you'll have excellent boost control with the way you have that setup. Good call on dumping the gates into the downpipe. I just hope those cheap ass gates last for you.
As do I. The decision to buy them came after the feedback i got from bailing on the Chinee turbo. ( seemed there were those out there that weren't having all kinds of problems with that stuff)
The three potential problems with the ebay gates are debris cutting the diaphragm, the valve sticking open/closed, or inaacurate boost or boost creep. I got # 1 fixed, I'll lube the valve w/ anti-sieze for #2, and the other is related to spring pressures. ( I may just buy a set of 5lb springs from Turbo Smart, and hope that they'll fit these T-smart clones to try and fix #3).
I have my regrets with the choice to use steam pipe. That monster hanging on the side of the engine probably weighs 35-40 lbs. I just hope I can get it looking good enough to coat it silver/titanium. The way it is now,..it's slotted for flat black.
At least I know I'll never have to worry about having to rebuild the bit ch again into the next decade tough.:nonono:
Its not like you are building this car to run a certain trap speed, so a little extra weight on the street will just help it ride nicer. It will also help balance out the 30-40 lbs youve been meaning to lose off the driver.
Ill have you know that the 6' tall "driver" weighs 180 pounds fully clothed. I do not need to lose an ounce.
As far as the car goes,..I agree. I was the one spouting off how adding weight to the notch I had last made it a more civil car to drive,....and this car starts even lighter than a 4 cylinder notch. I probably can add 200 pounds, and it'll still be lighter than a notch.
Chapter 3: Powertrain:
This has been a point of contention for me for some time,...as I want it to be different while trying to keep it Ford. After considering about 4 different paths (one of which was an LS option):eek:,...
I think I've decided to do all the work required to make the 3.3 liter, 200 c.i inline six that is currently in there work with a turbocharger. It's looking like I'll use Chinese turbo stuff,.blowing through two 1 bbl carbs mounted on a custom intake. An A2W intercooler w/ maybe a small (Schirocco style) radiator mounted w/ a dedicated 10" fan, coupled to an aluminum 1 gal fuel cell as a water storage vessel.
Adapted bellhousing to allow a SBF pattern trans to back the engine to handle the anticipated 350 whp/rwtq.​
a couple of things here, unless you have the low mount starter six, you cant use the V8 bell housing, unless you in fact build your own adapter, as none is available, unless you are planning to use a manual trans, in which case first try to search up a T4 trans bell housing from a fox body mustang with the 3.3, and you can use a T5 without an adapter.
as for using turbos with the one barrel carbs, i wouldnt recommend doing that, you are limiting yourself too much. a better idea would be to use two CFI throttle bodies from a V6 or V8 mustang or Tbird, and run them with a megasquirt controller. the nice thing about doing this is that the CFI throttle bodies is that you can mount them in a side draft deal increasing hood clearance for the blow through bonnets.
Dude, you read chapter one then skipped to the end of the story. The engine "evolved" to a 250, and now there is a megasquirt MSII in a box. If you are the same Rbohm that is on classic inlines, then you have commented to me there w/ respect to the same. Although all you had to do was read on here. the thread over there details the same. So,..no need for an adapter, or trying to blow through an emissions hobbled era one barrel carb.
Got this thing started yet? Hurry up, I can't wait anymore!!!
Man,..you are in for one hell of a long wait. I still have a bagillion things to do before the engine,..and most of it isn't even bought yet. I'm entering the "no-mo money" phase of the build. There are so many things that just require "sweat" in front of me, I'll have work for months to come.
So........get a beer and cool out.
Reactions: 1 users
yeah, sometimes i get lazy and wont read the full twelve pages of responses, as they sometimes get rather tedious. and yes i am the same rbohm. i usually respond to the post though without trying to figure out the user name and where i might have seen it before, unless i remember answering the question before. but since i post on several forums, i sometimes even forget that as well.
