@CrisNavarro how easy is it for you to search for info on this from Spain? I dont mind posting some links to other forums and sites here that are talking about this swap, but I dont want to clutter up your thread with info you can find yourself.
Thank you so much. I need to check all the options.I haven't put any 8.8s in a vintage mustang...but on my last '66 I did actually have a 7.5" with rear disc from a Mark VII if I remember correctly? The 7.5 and 8.8 in the fox were the same width...you can fit a 8.8" from a foxbody in a vintage mustang, but the wheel offset will change(more dramatically for 65-66 than for 67-68) so if you do so...you may be forced to use later model wheels(which also means you will need spacers to use them on the front). One way around it is to shorten the 8.8", but then you get into custom length axles, etc. It really depends on what you need as far as strength goes and what wheels you are wanting to use with it. The best axle choice is going to vary from build to build. That being said...the 8.8" is an excellent choice if you need something that comes with factory LSD and rear disc brakes...but it will require work to properly fit a vintage mustang. The 8.8" you choose needs to be thoroughly researched as well.(If I were to do the swap myself, I would choose an 8.8" from an explorer, shortened on the passenger side, and using 2 driver's side axles, then run whatever spacers were required to correct the wheel offset....its the most well-known way to do it...but there are plenty of other ways. The best unit you could start with for example would be a 2014 Mustang GT 8.8"....since its new and easy to find, the clutch packs would be in good condition...the downside being that custom length axles would be required(pretty sure the explorer axles inner spline isnt the same as the late model mustang, but I could be wrong on that).
That being said, there are plenty of others out there that would be able to give you better details than me on the swap.
I am from Spain, but I am working in Mexico at the moment.@CrisNavarro how easy is it for you to search for info on this from Spain? I dont mind posting some links to other forums and sites here that are talking about this swap, but I dont want to clutter up your thread with info you can find yourself.
Will be great to get this Combo!"Looking for the best combination 347 + gearbox + rear end. Suggestions?? " - CrisNavarro
Dream combo for daily driver street use - 347, G force WC T5, nine inch with worm gear posi and 3.25
This stuff would bolt in but might be hard to come by (read expensive) in Spain. Which is why it got a dana in the first place I imagine.
8.8 would be nice but not a bolt in because width and yoke style.
Bet you don't see many old mustangs driving around in Spain, fun to be different.
Here they are:We need more pictures of your car.
In progress is fine
Is really difficult to find cars like that...You'll be a hero if you bring home a Mustang hot rod!
You mean in Spain? Is left side"!Does it have to be converted right hand drive?
In Spain will be really really dificult, here in Mexico is more easy.I dont know how easy it is for you to search for information on a car that isnt really in your country of origin.
If I search for stuff things here in the states stuff from Spain doesn't come up. So if it is easier for me to search for stuff here in the states where that car is everywhere and post it here I can. If you are able to do simple searches to find info on your own I'm not going to post a bunch of stuff here.
Trying to be helpful IF you need it is all.
The owner told that is from explorer, no from fox, he write it wrong. There is a number code or something like that to differenciate a explorer version from mustang fox? Price was around 200 usd with 3.25 (or something like this), but he give me the oportunity to get the upgrade 3.73 for 200 usd extra, I decided 3.73 + T5 manual + transmision cardan.I haven't put any 8.8s in a vintage mustang...but on my last '66 I did actually have a 7.5" with rear disc from a Mark VII if I remember correctly? The 7.5 and 8.8 in the fox were the same width...you can fit a 8.8" from a foxbody in a vintage mustang, but the wheel offset will change(more dramatically for 65-66 than for 67-68) so if you do so...you may be forced to use later model wheels(which also means you will need spacers to use them on the front). One way around it is to shorten the 8.8", but then you get into custom length axles, etc. It really depends on what you need as far as strength goes and what wheels you are wanting to use with it. The best axle choice is going to vary from build to build. That being said...the 8.8" is an excellent choice if you need something that comes with factory LSD and rear disc brakes...but it will require work to properly fit a vintage mustang. The 8.8" you choose needs to be thoroughly researched as well.(If I were to do the swap myself, I would choose an 8.8" from an explorer, shortened on the passenger side, and using 2 driver's side axles, then run whatever spacers were required to correct the wheel offset....its the most well-known way to do it...but there are plenty of other ways. The best unit you could start with for example would be a 2014 Mustang GT 8.8"....since its new and easy to find, the clutch packs would be in good condition...the downside being that custom length axles would be required(pretty sure the explorer axles inner spline isnt the same as the late model mustang, but I could be wrong on that).
Thank you! I will check it!easy way to tell...an explorer 8.8 often has disc brakes and 5 lug, aside from the 93 Cobra, I believe all fox 8.8s had 4 lug and rear drums(though of course they can be changed to 5 lugs with the correct axles and rear discs) Also, the carrier is offset on an explorer rear end....the one axle is longer than the other(which is why shortening them people often use 2 of the shorter side axles)
