Engine Can’t find oil pressure sensor?
Cheezemypuffs
Texas
I’m doing a mechanical oil gauge for the first time on my 2009 v6. I just can’t find the port, I’m probably looking right at it around the oil filter but Idk what it looks like. I’ve seen tons of threads and videos online but I haven’t seen an 05-09 location pic or vid. Here’s some pics I took around the filter. Thanks
I think it’s this one , 1 gray wire coming out of , behind a lower radiator hose I think
That looks like it. If you take it out and get coolant instead of oil, we're both wrong, but that matches the pictures of the part I find online, and the one time I did one (was on a 2005 4.0 Mustang) I just remembered it being behind the radiator hose.
An oil pressure switch will typically have a single wire connector 'cause the switch body grounds where it's mounted near the oil filter, so I think you've found the correct one.
