FastSVO
Perfect...Thanks! Any recommendations on which caps to get? Does brand really matter here?It's the same.
I installed a YF-879 on my low side fitting on the actual compressor.
My caps are about 12 years old and I can only assume they are ok. Is it usually a good practice just to replace them?no. There's all sorts of caps for these lines so don't think the brand matters. I think the low side is 1/4 flare and the high side is 1/2 acme. Don't quote me on that though.
Problem is you shouldn't really be pumping moisture laiden compressed air into the compressor. Will just make pulling a vac more difficult. Should really use Nitrogen here, but not many folks will have a tank of this kicking around like I do.
