MS3PRO plug-and-play: Spare Outputs?
Mustang5L5
Mod Dude
Feb 18, 2001
41,840
17,447
224
Massachusetts
Anyone familiar with this unit? What does it have for spare outputs? Is there a single PWM output that can be used for Fan Module control?
From AMP/EFI website:
  • Automatic cooling fan activation with A/C, user configurable
  • Cooling Fan Control
  • Programmable fan on and off activation points
  • Can be configured to run fan with engine running only, or when engine is running and not running
  • Feed-forward idle up for use with large, high demand fans
  • Configurable fan deactivation based on TPS or VSS
  • 5 PWM outputs
  • 2 digital outputs
  • 12 analog inputs plus built-in MAP, Baro, and internal ECU temp sensor
  • 3 high current digital/pwm outputs
  • Any unused injector outputs can be used as high current digital or PWM outputs
I cherry picked the ones that apply.
But that's the universal unit.
I'm looking at the Mustang specific one. If you look through the installation guide, it shows wiring pinouts
This is the additional functions plug on the top of the unit. I don't see anything here i can use as a PWM output fr fan control.
Edit: Might be able to use L or P. I think this will work
This is the standard 60-pin hookup
