Im sorta disapointed right now with the times but im somewhat happy with them too, considering i was in full street trim. I even had my sub box and subs in the back. That and i tied my fastest NA time ,were i was using slicks, with my street tires (which are drag radials though)
The first run was made without heating the tires or letting out any air pressure. (37 psi) I spun like a mo-fo.
The next run i heated up the tires. And the runs after that i heated them and let out air pressure each time. The last time i was down to about 18 psi.
Here is the kicker... I hit the rev limiter in 4th a few times before i was even close to the end of the track. Actually the last run i shifted into 5th (probably hurt me). So i need either larger tires or new gears.
I can't wait to go back with my slicks/skinnies and take out all the extra added weight from the car.
I was using Nitto Drag Radials 35/315/17's.
You can see my 60's weren't all that great.. IF i can get down to a 1.7 im possitive its good for an 11 timeslip.
I was launching at about 2500 rpms at the end..
Im still looking for a mid 11 or better with slicks.
You can see for the most part that with each run i got better. My reaction times did too (weird)
One more thing, As soon as i get my pms and the car tuned i will go back with the same setup and see what kind of improvements it actually made.
