The 100GPH pump will do it.allcarfan said:100gph mechanical fuel pump good enough to support 450-500 hp with a 3/8" line?
I don't know anything about what fuel pump is needed, but the concern would be regarding the fuel consumption at an instant of time, with wide open throttle, at near maximum engine rpms. You really don't want the engine to go lean at that moment. The fuel mileage that generally can be calculated is an average which includes idling, cruising, etc. Therefore, the average fuel consumption per mile will be much less than the peak requirement of an engine.D.Hearne said:Think about it, just how bad would your fuel mileage have to be to use a 100 gph fuel flow ? I was running a 30 gph pump with the 400 hp 5.0 in my Ranger and never came close to using it all. With a 30 gph flow, it would have to be getting worse than 2 mpg to use all the flow. Unless you're going to go with EFI, you don't need all that fuel with a carb setup. Those HV pumps are highly over rated for carbs.
Even at WOT on say a 12 second car, at 100gph, you're flowing 43 oz's of fuel in 12 seconds, with a carb, that amount of fuel isn't going to flow thru 4 tiny jets in a 4 bbl in 12 seconds, with only the engine's vacuum pulling on the fuel. I ran my 427 with 2x4 bbl Holleys with the stock fuel line that the car came with , may have been 3/8 line on a big block Stang, but could also have been 5/16, I can't recall. The fuel pump I used was a stock pump for a 427/428CJ motor. Never starved it for fuel, even at WOT. Don't know what the flow rating was on that pump, but it was likely less than 100 gph.Hack said:I don't know anything about what fuel pump is needed, but the concern would be regarding the fuel consumption at an instant of time, with wide open throttle, at near maximum engine rpms. You really don't want the engine to go lean at that moment. The fuel mileage that generally can be calculated is an average which includes idling, cruising, etc. Therefore, the average fuel consumption per mile will be much less than the peak requirement of an engine.
I couldn't tell you how many times I've posted this link to Century Performance on different forums (including this one) but it's a must read:allcarfan said:100gph mechanical fuel pump good enough to support 450-500 hp with a 3/8" line?
My God I've created a monster Glad you math is better than mine.Hack said:Ok, I had to try to calculate this out. Yes, I'm a geek, but I'm proud!
weight of a gallon of gas ~ 6 lbs
weight of a std cubic foot of air ~ 0.0807 lbs
stoichiometric a/f ratio is 14.7 lbs air/1 lb gasoline
For a 427 cubic inch engine ~ 0.247 cubic feet displacement
Pick 6,000 rpm as a redline. Each cylinder will be filled every other revolution, so halve the rpms to calculate fuel usage. At 100% volumetric efficiency (overestimate, counteracting the fact that you will want to run a little rich and have some safety margin) ~ 742 cubic feet of air consumed per minute = 44,490 cubic feet consumed per hour.
44,490 cubic feet of air per hour ~ 3590 lbs of air per hour.
divided by 14.7, that gives you ~ 244 lbs of gasoline per hour.
divided by 6 gives you 40 gallons per hour.
So if a 100 gph fuel pump can actually deliver 100 gph, it looks like overkill for many applications. I'm forced to agree with D. Hearne. Seems like a good place for me to be.
