just bought an 88 lx,they put a new timing belt on,but no timing light.were is the best to set the timing. couldnt find info in chilton book. thanks
The oil pump sprocket on a 2.3 also drives the distributor. This means you often have to set ignition timing after changing the belt.At the timing marks depicted in the pics.
When did they switch to the coil pack ?The oil pump sprocket on a 2.3 also drives the distributor. This means you often have to set ignition timing after changing the belt.
Set your base timing at 10 degrees BTDC. Make sure you pull the spout connector (little black or gray plug inline on the harness) before loosening the distributor.
1991 on the Mustang. I've had two 2.3 cars, a 74, and an 88. I actually don't remember either of them having a mark on the auxiliary shaft sprocket (which drives both the distributor and oil pump).When did they switch to the coil pack ?
