1994 MAF and Headers ?
Discussion in '94-95 Tech' started by RAW2, Nov 16, 2009.
  1. RAW2 New Member
    Oct 31, 2009
    Message Count:
    I have a 1994 Stang Gt Convertible, I'm about to install a CAI and still have the stock MAF do I have to change it or can you tell me how to install it. On the headers I need to know if long tubes are better than shorties.
  2. tannerc91gt Advanced Member
    Mar 29, 2009
    Message Count:
    3,831
    68
    Long tubes produce a little more torque, shorties are MUCH simpler to install, I have them and like them. As for the maf your fine with the stock one
  3. earleys94gt Member
    Aug 31, 2003
    Message Count:
    824
    No need to change the MAF.
    The choice of header will depend on what your plans are for the car.
    For a daily driver, shorties will be fine. However, if you want to optimize the power band and do some racing then go long tubes.
  4. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,575
    78
    it is my opinion that long tubes are more trouble then they are worth. they are a pain to install and they can mess with the tune because of the way they move the O2 sensors farther away.
    nowadays, the gains you get from good shorty headers are almost as much as long tubes. not quite as good still, but it is alot closer than it used to be.
    i think also that equal length shorty headers are a not worth it. they make simple things like changing the spark plugs a real pain and they have a tendency to burn plug wires
    i think mid lengths are a good compromise.
    and the only time you need to worry about the maf is if you are changing the fuel injectors (because you are doing some mods and increasing the horse power alot)
  5. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,226
    68
    You're fine with the stock MAF.
    Long tubes are better but harder to install. Anything is better than the stock spaghetti headers. I have never had a single problem with moving the O2s farther away with long tube headers. I must have installed them on 20 cars by now.
    Kurt
  6. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,794
    76
    Are you concerned with the physical installation of the MAF? You remove the MAF from the air cleaner assembly (Remove the MAF pipe as an assembly. One end has 4 bolts and the other is round, like a throttle body).
    Then it just slips into the silicone coupler on the firewall side and then bolts to the CAI on the air-filter end.
    Though not quite apples to apples, the pics here might help:
    Mustangworld - Mac Cold Air intake
  7. RAW2 New Member
    Oct 31, 2009
    Message Count:
    Thank u guys the info was helpfull. Hissin50 thanks for the pics they were the most help.
Share This Page
