50specialist
After you clean the maf try unpluging the batt. The puter remembers the readings in the old maf and unplugging the batt for bout 5 min will reset everything to new readings. Also the dizzy has been known to go out and cause issues. keep troubleshooting
When you clean the maf, use contact cleaner. Just go to your local auto parts store. My maf sensor filaments of my 93 stang was covered in dirt, and after using the cleaner, it looked brand new again and can read the incoming air a lot better. MAF controls the engine practically, if anything is clogged, you will suffer.
