2.3l n/a reprogram computer???????
Discussion in '2.3L (N/A & Turbo)' started by jmy360, Jan 19, 2007.
  1. jmy360 New Member
    Nov 23, 2006
    Message Count:
    mexico
    Did anyone know how can reprogram the computer for my 4 cyl 2.3l n/a, that also can make a dynotest, in Houston or san Antonio and how much it cost, the engine has 6000 miles, k&n filter, no problems with sensor or vacuum leak, I use royal purple on the engine, transmission and differential
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Nobody can reprogram the 2.3 n/a computer...there was never a market for it so nobody messed with it.
  3. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    Indianapolis, Indiana
    If you could get the car to one of the Chip places they could put the car on a Dyno and custom burn you a chip.
    My dad had one burned for his Escort ZX2 back when there were no chips for them.
    He got lucky and they offered to burn it for free if he would let them keep the car all day. They wanted to use his car as the prototype for the new chip since no one had brought a ZX2 in before. Once they had all teh data and burned a chip and tsted it they could then list chips available for a ZX2.
    Maybe no one has bothered bringing a 2.3L n/a EFI car to them before.
    I say call them and see. Worse they can do is say "no go away".
  4. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,562
    66
    Antelope Valley, SoCal
    You also have to wonder how much an 88hp engine is going to gain just from a little more fuel and timing.
  5. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    What my dad did was performed all the mods then had them burn the chip so it maximized his efforts.
    Burning a chip for a stock motor would gain little if anything.
  6. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Doesn't work like that unfortunately...the Zx2's use the newer style ECU's with reprogrammable ecu's. With an SCT tuner or similar, you can reburn any of the newer ecu's so the ZX2 wasn't a problem for them. With the older ecu's though, the ecu's don't work that way...they require a piggyback system which requires somebody to sit down and break down all of the code which takes 100's of hours in many cases...just to get a definition file.
  7. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,562
    66
    Is the N/A ECU really that far removed from a 2.3T ECU?
  8. GOvert New Member
    Jan 27, 2007
    Message Count:
    64
    way south central Tennessee
    Hmmmm ?
    Hmmm... I wonder if you could adapt a ZX2 computer to the 2300 engine....?
  9. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    I swear I replied to this once before???
    Anyways, yes...it's completely different in every way...
  10. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    It's OBD-II so no...not so much...
  11. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    OK what about converting to a Megasquirt EFI computer and a Megajolt to control the DIS?
    You could completely control the fuel injection system and ignition timing with a latop computer attached.
  12. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,796
    78
    Lenexa KS
    Ahh, and finally, we have an answer of Yes. haha
    That's an excellent suggestion that has been throughly used by people on TF, and soon myself.
  13. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,562
    66
    Is this theoretical setup still going to be on a stock 2.3NA? I really like MegaSquirt, but factory tunes are generally very hard to improve on with a factory engine. I can think of one exception, but it's not a Ford.
  14. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    Dunno:shrug:
    if its a stock motor why would you bother changing it?
    If the motor is gonna be a built up N/A a Megasquirt and a Megajolt could just be the answer.
    Last I saw the MS kits were $100 and the MJ kits were still in reasearch.
  15. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,562
    66
    That's my point exactly. A 150hp+ N/A 2.3 could probably benefit from MS.
    I haven't seen any $100 MS-I v2.2 kits(I'd like to!), but MegaJolt isn't really necessary. I'm subscribed to the Yahoo! group, but lost interest after seeing all the other ignition options for MegaSquirt with MegaSquirt-n-Spark-Extra Code. There is an anti-lag version of the 2.25b code floating around that would great for a turbo rally car. :D
Share This Page
