4.10 gears illegal in CA??!!
Discussion in '2005 - 2014 Specific V6 Tech' started by Cobnial, Nov 27, 2010.
  1. I got off the phone with ford dealership and I asked how much it was to install 4.10 gear differential and he said that it was illegal to change the ratio of gears to any car in california. Is this true? Did i just talk to a dumb mechanic or is he telling the truth. I see that there are people in CA with these gears. How did you get away from emissions? or is this ford mechanic telling me lies?
  2. You were told straight up Bull****.
  3. No actually they are right. Changing the gear ratio means that they might have to shift out of 2nd gear on a loaded (dyno) smog test. Also you have to reprogram your computer to account for the new ratio, and any programming must have a CARB EO number.
  4. So just reprogramming the computer would fail my smog test? By the reprogram do you mean the speedometer issue? And if i do reprogram it back, cant i just tune my car back to stock before my smog test? will it pass then?
  5. wow, cali is screwin you guys hard.
  6. tell me about it makoto. its bad enough trying to save money to mod up your car, it's even worse not being allowed to cuz of emissions. I couldn't even buy a CAI of my choice cuz most are illegal. I think there were only 3 I could choose from. And dont remind me about cams and heads. theyre also illegal. it blows
  7. Wait wait WAIT. Certain CAIs are illegal?!!??!
    crap...
  8. Any engine mod you do to your car in CA has to have a CARB EO number that corresponds to your vehicle. Its real simple.
  9. Cali
    One more reason not to live in Cali...Unfortunately Cali emissions laws tend to spread to all of the states. Take note of who you vote for these people are everywhere.
  10. I have never heard the 4.10s are illegal here in Cali. When I was getting prices for gear install for 4.10s, not one place including the three dealerships I talked to-Mossy Ford, North County Ford, nor Heller Ford said anything about them being illegal. There labor charge should have been illegal though.
    Nemethjames1 likes this.
  11. So just to make sure as long as in general there is a CARB EO number I'm fine? Or do I have to find a number on my Mustang to make sure it matches in some fashion?
    Since if it's the former than I'm ok, latter though may be a problem.
  12. And I once thought Cali seemed like somewhere I'd like to live :rolleyes:
  13. gears are not illegal for ****s sake.
  14. Maybe the mechanic was an illegal? :shrug:
  15. Well played, I lol'd.
  16. I LOL'd just reading the title.
  17. I know this is an old thread but after reading it I just had to post.
    Someone has their head way up their a$$.
    I know its not a mustang but I just smogged my hemi ram with 4.56 gears, underdrive crank pulley, CAI, electric fan, Superchip, and headers.
    CAI and headers have EO numbers. Pulley they didnt even care. fan is not a smog item so it doesn't matter. I also have real duals instead of the factory 2 into 1 exhaust. That doesnt matter since its after the cats.
    As long as the tuner does not turn off anything it will pass the smog test. They will not even know its there.
    Gears do not matter because the test is at 15 & 25mph within certain rpm ranges.
    At 15 my truck was at 2300rpm which tells me it probably never got out of 1st because of the shifting I set up.
    My brother was a smog tech for 15+ years till he moved to a shop that didn't do smog.
    If you get a truck with big tires or gears just test in whatever gear you need. He had one that had to be done in 3rd for the 25mph test but it worked and passed.
  18. You guys still smog test 96+ vehicles? Smog machines here plug into the OBD2 port. The car either passes or fails based on if theres any codes in the computer.
    Chris
  19. They still smog test cars in CT too, the state privatized it a couple years ago so that regular garages can do it if they buy the stupid machine. It's $20, if you fail you can't register the car. They won't do new cars for the first few years, but after that it is every couple years.
