bucstang1 said:Does anyone know how much power a stock 7.5 will hold ??
Lex said:its fine for a 2.3 and OK for turbo , thats what I have. but I heard some stories about 5.0L with a 7.5 rear. defintly should have a 8.8 for them.
351coupe said:if you don't go around dumping the clutch and if the car doesn't do any wheel hope
CarbdFord.com said:I have run many a strong 5.0L in front of a 7.5" rear end. The ones that break are normally ones with the auburn traction lock unit in them. They tend to break spider gears for some reason. The Ford traction lock unit seems to hold up much better and is a clone of the one used in the 8.8 rear almost. Remember the 7.5 rear end uses the exact same axles as the 8.8. The weak point is the pinion shaft and the smaller spider gears. But I have not broken a ford traction lock unit.
CarbdFord.com said:Remember the 7.5 rear end uses the exact same axles as the 8.8. The weak point is the pinion shaft and the smaller spider gears. But I have not broken a ford traction lock unit.
351wcoupe said:Hey prohawk. You might want to rethink that torque thing I think I'm making a little torque. Now I have to pick up a little more traction.
yeah keep in mind the spray. On motor I'm not making 250ft lbs But I would expect to be close the 300ft lbs on giggle gas.Pro-Hawk said:Well put her on a dyno and post us some pics I know theres a few people whos dyno a modded 2.3T and got like 250-275ft tq out of them. But don't most 4.6/5.0s make like 300ft tq stock Once I get off my lazy butt I'll finnish my car and post some dyno pics my self.
mustanggrn said:OOPS! I'm at amanda's house. This is 351wcoupe
