88 lx mis-fires when warm
Discussion in 'Fox 5.0 Mustang' started by matty40, Jun 10, 2009.
  1. matty40 New Member
    Jun 9, 2009
    Message Count:
    I have an 88 lx 5.0 and after about 30 mins of driving it will start missing...will just skip once or twice. After a couple more miles it completly goes to 7 cyl and eventully stalls out. Then after the car cools down it runs fine again. Thought it was and ignition problem.. changed plugs,wires,cap,rotor,coil,ignition module. Still havent found it. The car is pretty much stock except,exhaust,cold air intake,and pulleys. I havent conv to MAF yet still speed density. Any help would be greatly appreciated.
  2. aar0s Founding Member
    Dec 20, 1998
    Message Count:
    1,719
    48
    i had a problem like this one time, it was the magnetic pickup in the dizzy. it would get hot and expand so that the plugs wouldnt fire. Not to say thats it but it sounds something like mine. had to let the car cool down before it would restart. pull the codes and see if anyting comes up.
  3. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,439
    11
    88
    Dumping The computer diagnostic codes on 86-95 Mustangs
    Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
    Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
    Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
    Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
    Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
    Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
    See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    What to expect:
    You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
    Alternate methods:
    For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
    Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
  4. matty40 New Member
    Jun 9, 2009
    Message Count:
    thanks for the input i will run codes and see what it says. Last time i did nothing came up. Do i need to do it while the engine warmed up and is missing?
  5. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,439
    11
    88
    That would be the best approach.
Share This Page
