90 GT vs. 03 V6
Discussion in 'Fox 5.0 Talk' started by DRock9, Dec 13, 2006.
  1. DRock9 New Member
    Aug 22, 2006
    Message Count:
    360
    Me and my friend decided to go down to my Dad's new development tonight and "race." He has a 03 V6 with a Pro 5.0 and a cat-back, while I have 1 5/8" BBK Unequal Headers and a 2.5" Mac O/R H-Pipe. Where we started there was all sand and it was a little up hill so I spun through all of 1st and 2nd, no idea how he did. Once I got traction in 3rd though every time I pulled on him without fail, but it was always extremely close and I know it shouldn't be. I am blaming it on my ****ty driving and launching, but I have two questions. Should it have been that close if he was only spinning through 1st and me 1st+2nd? And at about what RPM do you launch at? I ended up shifting at like 4,000 in 1st because I had no traction.
    Thanks! Im gonna go read up more on how to launch so ill be prepared for the track.
  2. 90 New Member
    Sep 25, 2006
    Message Count:
    20
    196
    launch at 4-5k.... red-line every gear!
    GO BIG OR GO HOME:SNSign:
  3. DRock9 New Member
    Aug 22, 2006
    Message Count:
    360
    4-5k are you kidding me? How don't you spin?
    Also I was shifting at low 5,000 because i read you hit a "wall" at like 5,200.
  4. Dean85GT New Member
    Nov 27, 2004
    Message Count:
    522
    Yeah...launch at 4000rpm on the sand that will get you far.
    If your car has normal street tires than basically just leave off idle and progressively push the gas. If the tires are spinning, your not going anywhere.
  5. 90 New Member
    Sep 25, 2006
    Message Count:
    20
    196
    i have street slicks vary low spinning almost none.. i never look at the RPMS when im shifting i listen to the motor you'll hear when shes done working that gear and them switch... ive never hit a wall tho i just assume its red-lineing when i shift...
  6. DRock9 New Member
    Aug 22, 2006
    Message Count:
    360
    Yea normal tires on this baby, I was going to try leaving off idle but it seemed waaaaay to logical to try.
    EDIT: Yea I don't look but the first week I had the car I memorized what sound went with what RPM so I'm guessing about 5,200RPM. Slicks would help for sure.
  7. Dean85GT New Member
    Nov 27, 2004
    Message Count:
    522
    Just shift at 5200 rpm, its about where the stock car makes peak power. If you shift too high it will just slow you down.
  8. DRock9 New Member
    Aug 22, 2006
    Message Count:
    360
    Yea thats what I figured, if we go there again ill try your tips. Thanks!
  9. FastDriver Moderator
    Sep 6, 2001
    Message Count:
    2,254
    48
    The stock tach can't be trusted. My stock tach told me I was shifting at 6000 rpm, and it went to 6800 rpm before the rev-limiter kicked in. Obviously, the stock rev-limiter was set at 6250rpm. I didn't know it at the time, but I was really shifting at around 5400 rpm, which works out to be just about right.
    Keep launching harder and harder until you find out where you can launch without spinning consistently. With Radial T/A's on 15" rims on a stock 5.0, the sweet spot was right around 3k rpm slipping the clutch.
    Anyway,
    Good luck. No '03 V6 should be even close. I had similar races with a buddy of mine, who took beating after beating until he finally came to the realization that his 200hp V6 wasn't a match for a stock 5.0.
  10. 90 New Member
    Sep 25, 2006
    Message Count:
    20
    196
  11. Busted07 I need my gorilla to be about an inch longer.
    Nov 15, 2005
    Message Count:
    333
    172
    There is like a 30-40 horsepower difference between a stock 5.0 and a 200hp v-6.. it should be a close race as long as the v-6 driver can launch and bang through the gears.
  12. 85ragtop Deputy Dawg Man woods surround my offic
    Nov 15, 2005
    Message Count:
    494
    264
    73
    Do you mean drag radials?
  13. 90 New Member
    Sep 25, 2006
    Message Count:
    20
    196
    no there still street tires.. i said it clearly.. STREET SLICKS
  14. FrankenStang Moderator
    Apr 16, 2005
    Message Count:
    3,472
    72
    78
    I don't underestimate the V6's. I have both a 5.0 and an '04 V6. For a V6, it's not too shabby.
  15. 85ragtop Deputy Dawg Man woods surround my offic
    Nov 15, 2005
    Message Count:
    494
    264
    73
    Go find me tire labeled “street slick”.
  16. cobra2798 New Member
    Mar 31, 2005
    Message Count:
    303
    I have 2 friends that both have 04 GT's with bolt ons and I beat them both, There is no reason why you cant rape a V6:shrug:
  17. 90 New Member
    Sep 25, 2006
    Message Count:
    20
    196
    they say ET : STREET ... and there slicks.. not drag at all
  18. 85ragtop Deputy Dawg Man woods surround my offic
    Nov 15, 2005
    Message Count:
    494
    264
    73
    I'll tell you what. Go to tire rack and look the up. Man I worked two years at a tire shop. Never mind. It's not worth it. You just keep on calling them slicks.
  19. 90 New Member
    Sep 25, 2006
    Message Count:
    20
    196
    when i took them to discount tire to get new ones they wanted to plug it and said they couldnt its a slick now... im not arguing with you my et streets are balder then a babys bottom... even if they wernt a slick they are now.. there is ZERO tred!
  20. 85ragtop Deputy Dawg Man woods surround my offic
    Nov 15, 2005
    Message Count:
    494
    264
    73
    I know the feeling. I have Traction T/A’s on my DD, and I had to get new ones yesterday. I could hardly drive it in the rain.
Share This Page
