SOLD 92 mustang coupe roller with shortblock
Discussion in 'Fox Body Mustangs For Sale (1979-93)' started by tannerc91gt, Mar 12, 2013.
Thread Status:
  1. http://imgur.com/a/xAnqy
    1992 Ford Mustang LX Coupe
    Original Florida Car.
    ABSOLUTELY RUST FREE
    Was originally green,
    painted Ford Lightning Red
    Grey/ Black LX interior
    Perfect Headliner
    Interior in near perfect shape
    All glass intact
    All Interior Intact
    Most of interior plastic has been painted black and ready to be put back in#
    Suspension
    UPR coil over conversion
    #Comp engineering 3 way adj rears
    Lakewood 90/10 fronts
    QA1 12”#150lb springs front
    QA1 CC plates
    single adjustable uppers
    double adjustable lowers
    Heim joints to body
    strangle axles
    8.8 rear end
    c clip eliminators
    5 lug conversion, extended studs in rear
    Moroso Trick Rear Springs
    Eibach Air Bag
    Weld Prostars 15x10s 6.5 BS with 275/60/15 BFGs
    Jegs 15x3.5s with 155 BFGs
    Ford 4:10 rear gear
    Trick flow Diff Cover
    V8 brake conversion
    # # Engine
    70's 351w 9.5 Block
    Balanced and 0 decked
    Bored .060 Over
    3.850”#rpm Crankshaftstock
    style rods with upgraded fasteners Speedpro Flat Top Hypereutectic Pistons w/ Dual Reliefs
    Canton 7 quart pan
    Pro products Single Plane Intake
    Holley 750 Carb
    Mac 1 3/4 Longtubes
    Compcams xe284H cam
    1”#Aluminum Carb Spacer
    Various gaskets
    Moroso waterpump drive conversion
    Moroso Rear Master Kill Switch
    Carb Cap
    Battery Relocation to Trunk
    gauge set (water, oil, a/f and tach) stock C5 transmission and custom driveshaft
    3 core aluminum radiator
    Catch Can
    1-wire 130amp Alt
    Full Mallory Ignition System
    Full carbed fuel system
    New clear headlights
    Car has no hood, would need cowl for the Windsor anyways
    no windshield wiper assembly, but the original setup will come with.
    May be forgetting a few parts
    Heads, valve covers pictured are sold
    Will answer all questions and should have any pictures you may need
    Located in southern Indiana
    $3,000 firm. Think that's a great deal, really need the car to go to a new home quickly
  2. Super! :nice: Go to the top of the thread and change your tag to SOLD. :)
  3. Don't think I can do that tapatalk style? If you would be so kind
  4. :nice:
Thread Status:
