- Aug 4, 2010
- 0
- 0
- 0
Ford Mustang GT 1994
The new rebuilt motor (it’s a DSS Pro Bullet block with internals and trick flow heads, cam, intake) was put in at 141k miles, the car has 147k on it.
ENGINE/EXHAUST
DSS 306 short block 8.5:1 compression
Trick Flow twisted wedge heads
trick flow track heat intake
trick flow stage 2 cam
65mm ford racing throttle body
80mm mass air meter
24lb injectors
throttle body elbow
intake spacer
trick flow valve covers
bbk ceramic long tube headers ***
bbk off road h pipe
borla mufflers dumped
3 core aluminum radiator ***
a/c delete ***
smog delete
160 thermostat ***
DRIVETRAIN
heavy duty t-5 5spd transmission ***
mgw short throw shifter
spec stage 1 clutch ***
ford racing flywheel ***
aluminum driveshaft ***
*** Indicates new part put in after new engine.
Car has new cooling temp sensors for the pcm and the gauge, new throttle position sensor, intake air control, new belt tensor, paint is original and has never been in an accident. Also has smoked headlights.
Asking $5,999
Call- 908 763 7190
ENGINE/EXHAUST
80mm mass air meter
24lb injectors
throttle body elbow
intake spacer
bbk off road h pipe
a/c delete ***
smog delete
160 thermostat ***
DRIVETRAIN
Asking $5,999
Call- 908 763 7190
