abs light on
Discussion in '94-04 V6 Mustang' started by bkstang00, Dec 2, 2008.
  1. bkstang00 New Member
    Apr 24, 2006
    Message Count:
    31
    brooklyn
    i have the abs light on my stang but dont know which one of the abs sensor is dirty or mess up?how do i find out?i dont want to go to the dealer cause theyre a rip off.
  2. hotcobra03 Premier Member
    Jul 25, 2007
    Message Count:
    1,000
    38
    poteet,tx
    Any codes to start with .and have you done or tried anything?
  3. bkstang00 New Member
    Apr 24, 2006
    Message Count:
    31
    brooklyn
    i havent done anything yet with it.im in the process of getting the abs scan tool to find out which wheel is setting off the abs light.one of my friends told me try cleaning the senors out to see if the senors are dirty?
  4. hotcobra03 Premier Member
    Jul 25, 2007
    Message Count:
    1,000
    38
    poteet,tx
    Is cel on also ?
  5. bkstang00 New Member
    Apr 24, 2006
    Message Count:
    31
    brooklyn
  6. hotcobra03 Premier Member
    Jul 25, 2007
    Message Count:
    1,000
    38
    poteet,tx
    Check engine lite .check all fuses with car running.under dash and engine compartment.check your owners manual for relay location .if the red brake light is also on will help with diagnostic
  7. Skymarshal Member
    Nov 5, 2004
    Message Count:
    572
    Dallas
    the ABS system generates its own trouble codes, and for the most part the system isn't designed to be worked on by anyone other than a professional. If you're able to tell which wheel is causing the light (assuming a wheel sensor is the problem), you might be able to tell if the sensor is dirty or bent, or if its wire is broken.
  8. bkstang00 New Member
    Apr 24, 2006
    Message Count:
    31
    brooklyn
    :bang: this problem is getting me mad.still find out the problem.thanx for all your help.:SNSign:
  9. wmburns Active Member
    Aug 14, 2009
    Message Count:
    2,640
    48
    Houston Texas
    Most of the time an ABS problem is a bad/dirty wheel sensor.
    Most auto parts stores will read DTC codes for free. Have you done this? It does take an advanced ODB2 scanner to read ABS codes. The auto parts store may be using an advanced scanner capable of reading the codes.
    Want know until you try.
    Without the DTC codes, it is just guessing (unless you want to check all 4 wheel sensors).
  10. bkstang00 New Member
    Apr 24, 2006
    Message Count:
    31
    brooklyn
    abs problems
    hi, i have the abs scan tool and cant get an connection.i was told to check the fuses,which i did.in the summer i had cleaned all wheel senors and still no connection with the system.the scan tool works cause i tested it on another car.i dont what else to do from here.thanx for your help.:SNSign:
  11. wmburns Active Member
    Aug 14, 2009
    Message Count:
    2,640
    48
    Houston Texas
    Please confirm the model year of your car. The original post does not state.
    Please confirm so that I can understand. Does your scan tool talk to the ABS sensors of other Mustangs? If so, which MY does it work with?
    Because if you are saying the fuses are good and the ABS module will NOT communicate, then then only other real option is a new ABS module.
    Before replacing, check the electrical connector at the ABS module to be sure it is clean and free of corrosion.
Share This Page
