auto shifting
Discussion in 'SN95 4.6 Talk' started by snowman23, Nov 5, 2009.
  1. snowman23 New Member
    May 2, 2005
    Message Count:
    172
    I did an extensive amount of research on this both here and other sites, but i have a question nonetheless. If a shifter for an auto like the B&M hammer shifter allows you to start in a lower gear 1 or 2 and then up or downshift as you wish, other than not being able to overshift from say 1-D or D-1, is it any better than just starting the stocker in the gear and then shifting it?
    Basically, I was considering this part, but would rather spend the money else where. I (believe it or not) like my automatic, but on occasion, I will start in 2nd, then upshift to D as I get going. Or occasionally from D-2 as I de-accellerate. I never use 1st. Is this safe to do? It would stand to reason that if the ratchet type shifters allow this, it would be ok so long as I do not miss the gear and jump too high or too low.
    Thanks
  2. KBExperience Active Member
    Jun 21, 2009
    Message Count:
    1,085
    48
    I have the hammer shifter And I absolutely love it! It makes the car a lot more fun to drive! Plus IMO it is worth it just for the looks. :nice:
  3. snowman23 New Member
    May 2, 2005
    Message Count:
    172
    It does look better than the stock one, i agree. I just am trying to remain budget minded so I was looking at this more in the future rather than right now. Basically the question I have is if the hammer shifter allows for upshifting and downshifting, is it safe to do this one gear at a time (so long as I do not miss the gear)?
  4. KBExperience Active Member
    Jun 21, 2009
    Message Count:
    1,085
    48
    upshifting is safe, but i wouldnt downshift very often unless you have a built/cooled tranny. downshifting causes a lot of excess heat. But you wont ever miss the gear, it only ratchets 1 gear at a time.
  5. snowman23 New Member
    May 2, 2005
    Message Count:
    172
    I plan on adding a tranny cooler sooner rather than later. I am considering the hammer shifter. At the moment, I usually drive around town with O/D off and occasionally will start out in 2nd and then upshift to D. I rarely downshift, just once in a while from D to 2 as I am approaching a stop (usually just to hear the exhaust growl :D). I never use 1st up or down. I was basically curious as to whether or not this is "ok" for the car (tranny in particular). I assume since this is the function that the hammer shifter serves that it would be ok.
    One other question, with the hammer shifter, can I leave it in D and just drive like stock?
  6. KBExperience Active Member
    Jun 21, 2009
    Message Count:
    1,085
    48
    Yes you can
  7. patman0911 Founding Member
    Jun 5, 2002
    Message Count:
    2,292
    46
    A shifter shouldn't affect operation in 'D' - you'd need a manual valvebody for that.
    Yeah, it's fun to hear the exaust burbling and backfiring while coasting down from high-RPM :nice: just keep in mind that brakes are wear items and cheap to replace and transmissions are not. For the most part though, the stock trans shouldn't let you do anything too stupid - if you shift down too far, the trans shouldn't shift into that gear if the RPMs are too high for it.
  8. KBExperience Active Member
    Jun 21, 2009
    Message Count:
    1,085
    48
    But that shifter is a PITA to install.. Well to get calibrated correctly.. The shifter cable is a little too short.. So you have to find a way to extend the cable or bend the linkage on the shifter
  9. snowman23 New Member
    May 2, 2005
    Message Count:
    172
    Sorry to be repeating myself here, but does this mean it is OK for the transmission to manually upshift from 2-D (with OD off) upon acceleration? I have to assume since the hammer allows ratcheting one gear at a time, using the stock one gear at a time would be ok too.
  10. KBExperience Active Member
    Jun 21, 2009
    Message Count:
    1,085
    48
    Yes it's fine
  11. snowman23 New Member
    May 2, 2005
    Message Count:
    172
    I also only downshift on rare occasion and usually am pretty good about making sure I am slowing down enough that the trans does not drop the gear and raise the rpms too much. In other words I don't drop it into 2nd at 60mph. I usually only do any kind of shifting around town at under 40 mph speeds. On the highway I 99.9% of the time leave it in D with OD on.
    I just wanted to clarify that since the hammer shifter allows the manual shifts, that I could assume the tranny could handle it on occasion with the stock shifter. Either way, a trans cooler will be on the to do list sometime soon.
  12. snowman23 New Member
    May 2, 2005
    Message Count:
    172
    Thank you for all the help.
  13. KBExperience Active Member
    Jun 21, 2009
    Message Count:
    1,085
    48
    no problem bro! that's what this place is for! :nice:
Share This Page
