Drivetrain Automatic Transmission Mount
Discussion in '1994 - 1995 Specific Tech' started by Killa, Apr 14, 2012.
  1. I need replace my automatic transmission mount, 1 bolt is keep turning and turning, and other bolt is loosing. what step i need to replace the mount ? thanks
    1995 mustang gt 5.0l automatic
  2. That's easy. Take the bolts out, jack the transmission up with a floor jack and replace it.
    Kurt
  3. do I need to take out the pan bar under it ? and 1 problem im having, is the bolt that is so loose, i cant take off.
  4. You can take out the whole crossmember and figure it out when you have it off the car. There are only 2 bolts holding up the crossmember.
    Kurt
