autometer tach
Discussion in '94-04 V6 Mustang' started by d.mccormick, Dec 9, 2007.
  1. d.mccormick New Member
    Dec 9, 2007
    Message Count:
    Ok I bought an autometer tach go's to 10k I believe. Well I have a 94 mustang 3.8l v6 coupe. Well there's the 4 normal wires. Red, white, green, black. Well from the back of the tach there's 2 wires brown and orange. I read on a site that v6 mustangs have to use those wires. . Any ideas where they go? I hooked my red to the battery, black to the fender bolts as a ground, white I didn't hook up and green I went in to the passengers side kicker panel and found the tan wire it a yellow stripe cut it and sauderd. Well the rpms aren't registering. .?!? Is it because of those brown and orange wires? It will let my move the shift light where your suppose to shift at. . Any ideas?????? How do you set it???? Thank you d.mccormick
  2. toyman Active Member
    Jul 20, 2007
    Message Count:
    1,259
    38
    You have a battery connection (red) ground (black) green (illumination) from the tan/yellow stripe wire which is likely the parking lamp feed. You still need the connection that will pick up the rpm signal probably from the coil. Have you checked the Autometer site to see if they offer wiring instruction?
    Haven't solved your problem but a search here will probably answer your question
    http://www.egauges.com/AM_Instr.asp
  3. StangGT1995 have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,294
    88
    Moved to V6 Tech.
Share This Page
