- Feb 28, 2003
- 204
- 0
- 0
i just started the rebuild and wanted to give you guys a rundown on what i got and what opinions you guys might have.
Forged 5.1L Stroker Kit
Kellogg forged Steel 3.75" Stroker Crankshaft
4340 forged steel H-beam 6.00" connecting rods
with ARP 7/16 cap screw bolts, bushed pin ends
Probe 2618 forged pistons, STD-0.020 bore
Total Seal or Perfect Circle Moly File fit rings
Clevite77 Rod and Main Bearings
Anderson F-52 cams and valve springs
Vortech mondo race bypass valve
2.87 upper pulley with new belt
i have bbk valve covers and was wondering if stock valve cover gaskets would work or do i need to try to get some from bbk. i'm debating on whether or not to have the heads p&p or to invest the money in longtubes. is their a good longtube header that isn't so expensive? what type of clutch would you guys recommend for this? any input from you guys would be appreciated.
