so i have a vortech v2 SQ supercharger installed on my car. it made 320 hp to the wheels at the dyno which i thought was a little low. the day i got it back i was takin a friend for a ride and after i dropped him off and went home the stang was acting really weird. it wasnt idling like it should. today i changed the spark plugs because i had just put in platinum plugs and then read that i shouldnt have used them. the cylinder closest to the front and the rear cylinder on the drivers side had both ate the tip off the spark plug....it just wasnt there. i changed the plugs back to copper and gapped them at .033 which is what iv read on here to be the best. the car is still not idling right. also i had bbk shorty headers put on and i have major leaks where they connect to the prochamber. when i would let off the gas the exhaust was making horrible back firing sounds. could this have caused the problems with the plugs. was the engine back firing. even after the plug swap the car isnt running right. does anyone have any suggestions. also if i could get the best specs to enter into the tuner that would be great. like shift points rev limiter spark advance af ratio.
here is the list of what is on the car.
vortech v2 sq
30# injectors with a MAF calibrated to them
80mm TB
ported plenum
bbk shorty headers
MAC prochamber
40 series flowmasters
xcalibrator 2 tuner
Thanks guys, i havent been able to drive the car since last october so im really anxious to get it running again. also if anyone knows a good mustang shop with a good dyno in the upstate of SC or lower part of NC that would be great to know as well.
vortech v2 sq
80mm TB
ported plenum
bbk shorty headers
MAC prochamber
xcalibrator 2 tuner
