Big Time Fuel Issue!! Please Help....
Discussion in 'Fox 5.0 Mustang' started by fivelitercoupe, Nov 9, 2004.
  1. fivelitercoupe New Member
    Nov 12, 2003
    Message Count:
    144
    Ok I got my new 94 GT and its having all kinds of fuel problems. Ok lets begin once the car is running the most fuel pressure i can get out of it is 25 and when you rev the car up or get on the gas it drops down to 10-12. We just recently put a walbro 155 pump in it and its got an aeromotive fpr also we just replaced the fuel filter to see if that would help at all and it didnt. When your drving thew car it wont pull above 3 grand in 1st and about 2000-2500 in all the other gears after that it just stumbles and falls on its face and cuts out. The problem seems to get worse the more you drive it. Any ideas, thoughts, comments, suggestions, etc. would be greatly appreciated......
    Thanks for the Help
    Brett
  2. ss93cobra Founding Member
    Apr 10, 2002
    Message Count:
    1,493
    Your pressure reading is with the vacuum off, correct? Plus, what did you set the regulator pressure at?
  3. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,449
    11
    88
    Dump the codes and see what the computer says is wrong…
    Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
    See http://www.troublecodes.net/Ford/
    OR
    See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
    OR
    See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
    IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
    For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
  4. fivelitercoupe New Member
    Nov 12, 2003
    Message Count:
    144
    Ok thats another problem that I'm having, I cant get the fuel pressure to adjust at all with or without the vacuum line off, i can crank the the screw all the way in or out and the fuel pressure wont change at all.....
  5. proxses Founding Member
    Dec 13, 2000
    Message Count:
    643
    The fuel pump might not be getting the voltage it needs. That's the only thing I can think of, unless you have a leak somwhere. And unless the leak was in the tank you would notice it really quickly.
    I say check the relay and see if the conections are corroded, and check voltage at the tank.
  6. shttygtstang New Member
    Jun 3, 2004
    Message Count:
    989
    whens the last time you changed the filter
  7. fivelitercoupe New Member
    Nov 12, 2003
    Message Count:
    144
    I changed the filter about 5 days ago so thats not the problem....
  8. fivelitercoupe New Member
    Nov 12, 2003
    Message Count:
    144
    Where is the relay at on an SN-95 car? I know the relay is under the seat on my coupe... Thanks for the help
  9. fivelitercoupe New Member
    Nov 12, 2003
    Message Count:
    144
  10. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,794
    76
    what codes did you get?
    one can carefully crimp the return line to narrow down whether the FPR or pump is at fault.
    if you have the stock FPR, have you put it back on to see what happens?
    are you sure your gauge is good? i did not think the car would run with such low pressure.
    good luck.
  11. fivelitercoupe New Member
    Nov 12, 2003
    Message Count:
    144
    i havent had a chance to run codes on it yet and i wish i still had the stock fpr but i cant seem to find it to throw it back on. I think the gauge is fine but when the fuel pressure drops that low the car barely runs or it'll die out when ur on the gas...
  12. fivelitercoupe New Member
    Nov 12, 2003
    Message Count:
    144
    Lastly, Will dead injectors cause a loss of fuel pressure and without running codes how can you tell if an injector is not firing?
    Thanks for all your help guys!!!
  13. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,794
    76
    one can use a noid light to see if the injector is getting a ground pulse from the puter (and has 12 volts supplied). a balance test is the best test, IMHO. it is part of the code running tests.
    good luck.
  14. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,449
    11
    88
    Fuel Pump Troubleshooting for 91-95 Mustangs
    Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
    No fuel pressure, possible failed items in order of their probability:
    A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
    B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
    C.) Clogged fuel filter
    D.) Failed fuel pump
    E.) Blown fuse link in wiring harness.
    F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
    The electrical circuit for the fuel pump has two paths, a control path and a power path.
    The control path consists of the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the relay coil and then from the relay coil to the computer (light blue\orange wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
    The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (pink/black wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the pink/black wire to the contacts and through the dark green\yellow wire to the inertia switch. The other side of the inertia switch with the brown\pink wire joins the pink/black wire that connects to the fuel pump. The fuel pump has a black wire that supplies the ground to complete the circuit.
    Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
    See http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif for a diagram of the wiring for 90-93 cars.
    See http://www.autozone.com/images/cds/gif/large/0900823d801ddb43.gif for help with wiring on 94-95 cars
    And
    http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for more wiring help for 94-95 cars
    Now that you have the theory of how it works, it’s time to go digging.
    Note that all the relays on 94-95 models are in the relay control box under the hood.
    Power circuits:
    Power feed: Look for 12 volts at the pink/black wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring, or connections. Remember that on 92 or later models the fuel pump relay is located under the Mass Air meter. Watch out for the WOT A/C control relay on these cars, as it is located in the same place and can easily be mistaken for the fuel pump relay.
    Relay: Turn on the key and jumper the ECC test connector as previously described. Look for 12 volts at the dark green\yellow wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
    Inertia switch: Check the brown/pink wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the dark green\yellow (inertia switch input) and brown/pink wire (inertia switch output). Power on the dark green\yellow wire and not on the brown/pink wire means the inertia switch is open. Press on the red plunger to reset it to the closed position. Sometimes the inertia switch will be intermittent or will not pass full power. Be sure that there is 12 volts on both sides of the switch with the pump running and that the voltage drop measured across the switch is less than .75 volts.
    Control circuits:
    Relay: The red wire for the fuel pump relay coil gets its power feed from the ECC relay. No 12 volts here, and the ECC relay has failed or there is bad wiring or bad connections coming from it. The ECC relay is located on top of the computer, which is under the passenger’s side kick panel. It is not easy to get to, you must have small hands or pull the passenger side dash speaker out to access it.
    Relay: The light blue/orange wire provides a ground path for the relay power. With the test connector jumpered according to the previous instructions, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the light blue/orange wire on the fuel pump relay. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. Remove the test jumper from the ECC test connector. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
    Computer: If you got this far and everything else checked out good, the computer is suspect .Remove the test jumper from the ECC test connector located under the hood . Remove the plastic cover over the computer wiring, but leave the computer wiring connector plugged into the computer. With the ignition switch in the run position, connect a test lamp to the battery and back probe pin 22, the light blue/orange wire with it. The lamp should glow brightly. No glow and the computer has died a sad death. :( If you used a voltmeter instead of a test lamp, you should see less than 1 volt.
Share This Page
