My 2006 Mustang GT has a small leak in the radiator and brake. Against my better judgement, and because I was in a pinch, I had my oil changed at Jiffy Lube (never again) and a few days after that I noticed the "Low Brake Fluid" light come on and put brake fluid in. I noticed fluid once on the right rear wheel.
About a month ago I saw that my temperature gauge was in hot. When I opened the radiator I saw that it was dry. I have to put radiator fluid in it about once a week. I don't notice any leaks on the ground.
Lastly, when I had my tires replaced, the mechanic said that the car "hiccups" when it is in gear (it's a 5 speed) if I don't give it enough gas. He said that either the fuel pump or the catalytic converter would probably need to be replaced.
Any thoughts?
Thanks, as always.
Any thoughts?
Thanks, as always.
