Brakes
Discussion in '2005 - 2009 Specific Tech' started by Steel Horse, Aug 6, 2009.
  1. Steel Horse New Member
    Oct 28, 2008
    Message Count:
    231
    Altoona, IA
    Has anyone seen or used some of these kits that use the stock calipers with 14in. rotors? They come with a relocation bracket for the caliper so it will fit over the bigger rotor. I realize these won't be as good as a full on big brake kit but was wondering if there would be a performance gain with one of these setups.
  2. SpartaPerformance StangNet Sponsor
    Nov 5, 2006
    Message Count:
    1,816
    38
    Long Island NY
    It will be noticeable, think of it as a lever arm the bigger rotor with the caliper relocated will be applying more stopping power like adding length to a wrench to apply more torque to remove a bolt.
  3. ct07gt Member
    Feb 15, 2008
    Message Count:
    355
    How much is the kit? It might be worth getting a set of take-off GT500 brakes off Ebay, there are some good deals if you are patient. Just better pads and stainless lines would probably more of a difference than a rotor swap.
  4. Steel Horse New Member
    Oct 28, 2008
    Message Count:
    231
    Altoona, IA
    Tommy that's kinda what I was thinking just looking for someone else to verify.
    ct07gt I don't remember how much it was for sure. I was doing some late night web surfing and came across it. I think the kit was made by Baer though.
    Edit: I found them here is a link
    Baer EradiSpeed-Plus-2 Front Rotors 2005-09 Mustang GT - 2261026
  5. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    Central VA
    Increasing rotor size and not also increasing caliper/pad size will not increase breaking performance. The pad will have the exact same size contact patch as the stock rotor...
  6. Steel Horse New Member
    Oct 28, 2008
    Message Count:
    231
    Altoona, IA
    I would think that moving the contact patch farther away from the hub would help a little.
Share This Page
