C4 install help needed PLEASE!!!!!!
Discussion in '94-95 Talk' started by BlkBoostedV6, Dec 16, 2006.
  1. BlkBoostedV6 New Member
    Dec 1, 2006
    Message Count:
    18
    Alright guys, I just got my C4 conversion kit from Art Carr, C4 w/brake full manual reverse pattern VB, SFI bellhousing, SFI flywheel, SFI sheild 9.5" convertor ect..... I got the AOD out already and the C4 up in place but the transmission mount doesnt line up with the crossmember? WTF??? I was told it was a direct bolt in basicly. Is there a special crossmember or adapter that I need? This is the only thing holding me up at the moment. PLEASE HELP!!!!!!
  2. Redsnk95 Founding Member
    Feb 4, 2002
    Message Count:
    2,246
    It is a straight forward swap with the exception of making a crossmember brace. All I did was get a 3/8" thick piece of steel plate. Drill some hole and use it to connect the C4 mount to the crossmember mount. Real easy to do.
  3. TurboSnake95 Founding Member
    Mar 15, 2002
    Message Count:
    1,412
    Dido, thats all I did. Ill take a pic tomarrow for u and post it.
  4. ponyboy19 Founding Member
    May 24, 2000
    Message Count:
    1,737
    I installed the C4 and jacked the transmission up into place. I then installed my crossmember and took the 3/8" plate (that I had already drilled to fit the tranny mount bolts) and marked it out from the tranny to the crossemember. I then cut off the excess plate and just welded it to the the crossmember. In doing it this way I could bring the plate off the top of the crossmember flush so I didn't have a 3/8" height difference like I would have had it been bolted to the top of the crossmember. The swap is straight forward you just have to make the tranny mount.
  5. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,285
    68
    subscribing
  6. Redsnk95 Founding Member
    Feb 4, 2002
    Message Count:
    2,246
    Just buy something already...:) :)
  7. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,285
    68
  8. Redsnk95 Founding Member
    Feb 4, 2002
    Message Count:
    2,246
    Hello from the 10 sec zone!!!! Won't you come and join me?
  9. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,285
    68
    More to life than a gutted race car:)
  10. Redsnk95 Founding Member
    Feb 4, 2002
    Message Count:
    2,246
    I don't have a problem going for a cruise with ya....
  11. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,285
    68
    How about a road trip to AZ w/o a trailer:)
  12. Redsnk95 Founding Member
    Feb 4, 2002
    Message Count:
    2,246
    Wouldn't be a problem for my car.
  13. TurboSnake95 Founding Member
    Mar 15, 2002
    Message Count:
    1,412
    didn't forget about the pic, just need to find the camera:bang:
    Will:flag:
  14. TurboSnake95 Founding Member
    Mar 15, 2002
    Message Count:
    1,412
    O.K here is a pic, not the greatest, but didnt feel like jacking up the car to get a btter shot. You can see the idea.
    [IMG][/IMG]
  15. BlkBoostedV6 New Member
    Dec 1, 2006
    Message Count:
    18
    That pic is upside down correct? Or is my head all twisted right now? Anyhow Thanks for the help guys. I made an adapter and it seemed to work fine. Its a totally different car now with the Manual C4 as appossed to the stock AOD. Hopefully you guys can help me out on my next MAJOR overhaul
    http://forums.stangnet.com/showthread.php?t=677368
    Now I'm looking to make some real HP #'s for the STREET!!!
    Thanks Again
  16. TurboSnake95 Founding Member
    Mar 15, 2002
    Message Count:
    1,412
    Ya, it's upside down :nice:
    Will:flag:
  17. Kornnut Founding Member
    Nov 25, 2000
    Message Count:
    1,999
    48
    Don't mean to OT the thread but how do you guys like your c4? Are they streetable enough for say an hour trip to the track and back?
  18. ponyboy19 Founding Member
    May 24, 2000
    Message Count:
    1,737
    Sure if your rear gearing is soft enough or you don't mind the increased rpms. I currently run 4.30's and the rpms are a bit to steep for a lot of extended street driving and I wouldn't even think of stepping on the express way with it. But with a set of 3.55's it would be alright.
  19. Kornnut Founding Member
    Nov 25, 2000
    Message Count:
    1,999
    48
    I plan on swaping my 4:10's out for a set of 3:55's or taller here soon. :D
  20. BlkBoostedV6 New Member
    Dec 1, 2006
    Message Count:
    18
    I just installed the C4 a few days ago and must say It does turn the R's with 4:10 and 55mph, I too will be switching them out in the near future and I've only drove the car 3 times with the C4
Share This Page
