I have a 2000 GT and the camber is off so badly on the front drivers side tire that its making a bald spot on the outer portion of the tire. My entire car is 100% stock so I haven't messed with any suspension stuff. I called NTB to see if they could fix it and the guy claimed that for a 2000 stang the camber can't be adjusted without adding camber adjustment plates (which is a bit pricey for just a small adjustment). I called another NTB store and the guy said they could adjust it no problem . Does anyone know if the camber can be adjusted without buying adjustable plates? Thanks.
