R rculjak Founding Member Jan 29, 2001 190 0 0 May 14, 2004 #1 May 14, 2004 #1 Hey guys, I am trying to properly set my stud mount rockers, can I do a compression test with the upper intake off?
J Js5ohLX Member Apr 5, 2004 287 0 16 Ohio May 14, 2004 #2 May 14, 2004 #2 sure, just make sure you take the coil wire off, you wouldn't want it to start up
R rculjak Founding Member Jan 29, 2001 190 0 0 May 14, 2004 #3 May 14, 2004 #3 cool, but will it be accurate compression with the upper intake off? I pull off the 12 volt feed for the coil and disable fuel.
hllon4whls BANNED Founding Member Jan 17, 2002 2,567 0 46 Covington May 14, 2004 #4 May 14, 2004 #4 Yes, it is just like wot maybe a little better. Remember that you dont really care what the total PSI is, just the evenness between cylinders. Dont forget to take all of the spark plugs out.
R rculjak Founding Member Jan 29, 2001 190 0 0 May 14, 2004 #5 May 14, 2004 #5 so what should I be hoping for with a stock bottom end with 100kMiles and new heads?
