Clutch acting funny
COramprat
...I can take it. I think.
Dirt-Old 20+Year Member
Mar 2, 2003
8,475
1,619
223
Sea of Tranquility
Sometimes when I have the revs up the clutch feels like it isn't disengaging. I get a flutter feel in the pedal and it sounds like when you try to put it in gear without the clutch...sort of chatter sound but not a grind.
If I shift normally it does fine. It is only when I shift hard and have the revs up between shifts that it does this. I can disengage, rev it up and when I select a gear it will do this also. This clutch is only about a year old so I'm not sure if it could be worn this quickly. I tried adjusting the firewall adjuster and it helped some but still have the problem.
