Code 332 Help
Discussion in '94-95 Tech' started by DDSTANG94, Oct 30, 2009.
  1. DDSTANG94 New Member
    Dec 9, 2006
    Message Count:
    467
    FRASER, MICHIGAN
    I got code 332, insufficient EGR flow? what does this mean? How to fix it. New EGR? Clean it?
  2. yukisho Rocky Horror Fan #1
    Apr 5, 2009
    Message Count:
    3,235
    92
    88
    Saint George, Utah
  3. DDSTANG94 New Member
    Dec 9, 2006
    Message Count:
    467
    FRASER, MICHIGAN
    ok, thanks you for the link
    Im still lost tho, what to replace or clean
  4. DDSTANG94 New Member
    Dec 9, 2006
    Message Count:
    467
    FRASER, MICHIGAN
  5. DDSTANG94 New Member
    Dec 9, 2006
    Message Count:
    467
    FRASER, MICHIGAN
    bump..someone knows
  6. BLOWN347STROKER Member
    Jan 13, 2009
    Message Count:
    237
    topeka kansas
    I would take off and clean/replace the egr valve. The are pretty easy to get to. Depending on how much they cost I would just replace it. I would also clean out the egr tube from the header to the valve. Another option would be to buy a block off plate and a cap for the header and a egr delete sensor plug. I think it cost me around 50.00 to delete my egr setup which in most cases is cheaper that buying a new egr valve but I would try to clean it up first if you want to keep it. It will probably end up needing replaced though. Good luck
  7. DDSTANG94 New Member
    Dec 9, 2006
    Message Count:
    467
    FRASER, MICHIGAN
    Thanks..ill give cleaning it a shot...:nice:
  8. chaos254 Founding Member
    Jul 28, 2002
    Message Count:
    426
    28
    Pittsburgh, PA
    I'm having the same issue... was on my way to the smog shop and the check engine light comes on so I had to turn around. Ran codes and coming up with a 332. When I started it up today there was no CEL on. Can anyone else give some more suggestions as to what could cause this? I just put on a brand new motorcraft egr on. My smog/egr has been deleted for years but I now live in lovely CA so deleting it is not an option. Could there be an issue with the sensor itself?
  9. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    they wont test with the check engine light on?
    mine passed with no problems with the cel on when i first got my car.
  10. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,855
    78
    Make sure the vac line is attached and that the position sensor is connected.
  11. chaos254 Founding Member
    Jul 28, 2002
    Message Count:
    426
    28
    Pittsburgh, PA
    Everything is hooked up, checked the green vaccum line going to the egr valve. All vaccum lines look good. I'm going to replace the sensor since its cheap.
  12. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    The EGR gets full of crap pretty frequently and doesn't flow properly. They just have to be changed out every once inawhile. If you delete your EGR, it will effect your fuel economy, give you a check engine light, and may cause mid throttle pinging.
    Kurt
  13. Road_Runna Member
    Dec 23, 2002
    Message Count:
    533
    Ogden, UT
    I had the same problem a long time ago. I replaced the EGR and still got the same code. The problem was those 2 plastic/tube lines that go into the fender.
  14. andr3w51 New Member
    Jul 13, 2009
    Message Count:
    11
    South Jersey
    i'm also getting code 332, my egr tube was kinked when aftermarket headers were put on. since i can't find a new tube to match up to my headers someone suggested using a piece of heater hose for a new egr tube. would this work? would the header get too hot and melt the heater hose? does anyone have any other suggestions for replacing egr tube for car with aftermarket headers? such as a egr tube made to be bent or something? thanks
  15. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,855
    78
    Not a good idea. You might be able to use copper.
  16. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    If you have a flare tool, you can use copper.
    Kurt
  17. andr3w51 New Member
    Jul 13, 2009
    Message Count:
    11
    South Jersey
    like soft copper tubing? the kind plumbers use? so i should just take the end fittings off the kinked egr that i have and put them on a piece of soft copper tubing, and flair the ends and that should be it? how much does flare tool usually run? is it something i can pick up at an autozone or something
  18. chaos254 Founding Member
    Jul 28, 2002
    Message Count:
    426
    28
    Pittsburgh, PA
    TTT...still having code 332(insufficient egr flow) issues. So far I have a new motorcraft egr and sensor. Does anyone have an egr schematic? I don't know what else to check. I'm thinking it has to be a vaccum line but I already checked all the lines and didn't see any cracks or broken lines. Is it possible a vaccum line could be clogged?
  19. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,855
    78
    I'd (at least) temporarily run a new line to and from the EGR solenoid. Just to rule out a bad line....
  20. 95steeda Member
    Oct 14, 2003
    Message Count:
    30
    Did you check the port that the EGR goes into on the intake? You can get a significant amount of buildup there.
Share This Page
