Here's the thing, just be careful what you invest in the project.
Which may or may not be someone's fault, regardless it happens.
If you don't have a mechanical oil pressure gauge, get one.
Spend the minimum on this engine until you are absolutely sure it's good.
I'm an oil pressure and coolant temp gauge hawk, even the slightest outside the norm and i investigate.
The reason i ask is that a blown head gasket can ruin the bearings when you drive it.For a while but i haven’t driven it once innoticed the milky oil. As for the temperature a while this past summer .I haven’t had a problem with the oil but yes I do notice when I tried to burp system that I had bubbles in the radiator
