DTC code
cruisinV6
240
SE Minnesota
I got a diognostic code of 5284 which is a oil pressure switch faliure code, my check engine light is on, but my oil pressure is fine when running. So whats up with it? havent changed oil recently, and it doens need it for another 1500 miles or so. can i just reset the computer and things will be fine?
If you are seeing a pressure switch failure, I would be concernced. Your oil pump may be acting up and not pumping enough oil through the engine. At normal running RPM's your pump may be pushing enough, but I would not reset and forget about it!
i called the local Ford dealership and the service guy told me that he has never heard of any code like 5284. all codes start with letters. I got the code from the digi odometer, cuz i got a 99 where i can pull the dtc codes there. I asked if i could jsut reset my computer and see if the light comes back on, he said to try it.
I dont know if this has anything to do with it, but it has been extremely cold here lately, colder then it has ever been since i have owned the stang, could simple cold weather cause my oil to thiken a bit therefore maybe getting lower pressure at some point, like start up?
also, can the cold weather cause a slight knock in the engine? i think i might have one, but am not quite sure if its the engine.
That is DTC common on 99+ cars and is NOTHING to worry about. The DTC from the odometer only show malfunction of sensors used for the guages and not engine operation or performance.
Chances are the code will return, but are nothing to be concerned about.
cruisinV6 said:
went to auto zone today to get the codes pulled. The guy said it was one he never saw before and that it is likely an emmisions thing. like you said, some sensor.
Getting codes pulled from the EEC is totally different system than the DTC;s on the guage cluster. You are confusing the 2 systems.
DTC's have nothing directly to do with emissions.
Eegads, the misinformation here is BRUTAL!
Okay, to start, here's how Diagnostic codes work. And frankly I cannot BELIEVE the Ford tech didn't know this. He should be fired.
Codes do start with a letter. Like P0xxx, P1xxx, P2xxx, P3xxx. Those are all POWERTRAIN codes, 400 of them (hence the P). They refer to powertrain (engine, tranny) functions as well as emissions systems. Then you have C0xxx-C3xxx These are CHASSIS codes. Then you have BODY codes, B0xxx-B3xxx, and COMMUNICATION codes, U0xxx-U3xxx. That's 1600 codes.
Now, in a computer, you need to represent these codes as 16-bit numbers. There is no P or U in a computer, we use hexadecimal, so with a bit of manululation you get:
P0xxx = 0xxx
P1xxx = 1xxx
P2xxx = 2xxx
P3xxx = 3xxx
C0xxx = 4xxx
C3xxx = 7xxx
B0xxx = 8xxx
... (remember hex digits, 0-9,A,B,C,D,E,F)
B3xxx = Bxxx
U0xxx = Cxxx
U3xxx = Fxxx
Soooo, in short, 5284 = C1284. Your Ford tech should have known that. GM uses the exact same code structure, I know that for a fact, and I'd bet Chrysler does too.
As to the code itself, it's not an emissions code**, it's an Oil Pressure Switch code, just like the description says. And it's not an uncommon one - SEVERAL 99+s show this code ON THE CLUSTER occasionally, it's nothing to worry about. There's probably a slight blip in the oil pressure signal from the sensor, and the cluster picks up on it and sets the DTC.
It's correct that the cluster codes have nothing to do with codes that may or may not be in the EEC (they're the same codes numerically and mean the same, but a code set in the cluster does not mean the code is set in the EEC as well, and visa versa). The cluster sees the oil pressure signal from the sensor just the same as the EEC does. The fact that the CLUSTER has set that code while the EEC hasn't (if the EEC had set it too, you'd have a SES) just means that the cluster is more picky (probably TOO picky) about that particular diagnostic routine than the EEC is.
Ford, I'm sure, knows about this issue, but since it's a diagnostic issue, and not a problem with the switch itself, and since only the CLUSTER usually detects it, and no SES is usually set, there's really no reason to do anything about it.
Particularly when Ford's own mechanics don't seem to know how to read codes properly. :shrug:
Edit: Just saw that you ARE getting a SES. If your gauge is still reading okay pressure, and the car runs fine, then it's more than likely it's the same 'blip', just bad enough that the EEC is setting the code in addition to the cluster. I'd bet if you cleared it, it'd go away. If it keeps coming back, I might check the oil pressure sensor connector and terminals, or maybe replace the sensor. Either way, your engine is OKAY. It's just that top-notch Ford quality coming through. ;)
**Note DTCs certainly CAN have to do with emissions. Several of the Powertrain codes are devoted to emissions systems such as EGR, catalyst operation, and fuel tank/canister systems. If the EEC detects an issue that would seriously affect emissions (like an EGR problem), it will set the appropriate code just as if it were a performance issue. Caveat being that usually emissions diagnostics are much 'softer', i.e. they are more loosely calibrated and generally take longer periods to set.
If you look at the list of trouble codes for the gauge cluser DTC, there are no emissions components listed. I'm referring "DTC" as the guage cluster trouble codes and NOT OBD-II/EEC codes.
Correct, the cluster only runs diagnostics for signals relevant to its operation, like battery voltage, fuel sender, things like that.
I did try to reset the computer already and nothing changed. i left it for nearly 15 mins and the service engine soon came back on. I figure its nothing hue, car runs fine, but that light is really anoying and i want it to go off. anything i can do?
I am having the same problem. When I reset it it may take it 1 to 3 days to come back on.
After watching carefully I noticed it comes on when I come to a hard stop but not every time I come to a hard stop.
I was and am worried about oil starvation but I also noticed about the time this started the car started bogging also at hard stops and idles rough for a minute so this may be the problem.
I changed the fuel filter and am gonna change the plugs and see if that helps the idling and the light problem
