I got my 99 all converted to the 94 5.0 drivetrain and it runs good. Most of my electronics work fine.
When I go to turn the key to the "on" position, my wipers jump a little but they don't do anything. They also jump again when I turn the ignition off.
Also, the wipers do not work at all with the switch.
When I got the car together and running, the wipers and washer motor were running constantly. I figured it was because I retained the multi function switch and harness from the 99. So I dropped the column and swapped the little harness and multi-switch and now I'm having the above symptoms.
Another thing is the top motor. When I pull the E brake up and operate the top switch, I can hear the relays clicking but the pump does nothing. I was told in passing one time that the top pumps in 99-04 cars are different from 94-98's. Any truth in that? Will I have to purchase a 94 style top pump?
Other than these two hickups everything seems to be working fine. Any brainstorming is greatly appreciated!
