estimate my horsepower/torque
Discussion in 'Fox 5.0 Talk' started by project67, Nov 20, 2009.
  1. project67 New Member
    Feb 27, 2006
    Message Count:
    116
    what do you guys think this combo is capable of with a good dyno tune?
    331 engine 10.2 compression
    gt40 irons heads, ported and polished.
    cobra cam
    1.7 roller rockers
    ported/polished explorer upper/lower
    70mm t/b and egr spacer
    24lb injectors
    70mm cobra maf
    long tube headers
    190lph fuel pump
    aeromotive adj fuel psi regulator
    by the way its a 5 speed car. i will dyno it around jan or feb i was just wondering wha it may put down. i know the heads are the bottleneck but after i get it passed smog i want to do a head and cam swap but need to save some more $$
    anyway i've been working on this and may have it running this weekend.
    :flag:
  2. Cobra912 Active Member
    May 1, 2005
    Message Count:
    1,843
    38
    Wish I was anywhere but here
    285 / 270
  3. tmoss Gettin Wired
    Jun 28, 2001
    Message Count:
    7,114
    78
    Saint Louis, MO
    I'd guess 300+RWHP and 340 lb-ft.
  4. tannerc91gt Advanced Member
    Mar 29, 2009
    Message Count:
    3,933
    18
    68
    Indiana
    275ish...not sure what a cobra cam is
  5. time only New Member
    Nov 15, 2002
    Message Count:
    485
    Miami,FL
    Cobra cam
    Crane 2031 ?
  6. Bullitt347 Active Member
    Mar 24, 2007
    Message Count:
    692
    42
    38
    Pacific NW
    Depends on the port job on the GT-40 heads. They are very sensitive to work in the area just under the valve seat. If that is messed up, so are the heads. If done right, 300 whp and 330 lb/ft torque. I put together a few 93" Cobra engines with good success. Ported GT-40 heads, Steeda #19 camshaft, ported lower intake, Extrude Honed upper intake, Bassani Equal length shorty headers, Bassani Cat X-pipe, Bassani Cat back. Both engines made 300 whp and 330 wtrq. Not Bad for a stock short block, and modified stock parts.
  7. project67 New Member
    Feb 27, 2006
    Message Count:
    116
    its just a stock cam from a 93 cobra. my initial goal will be to run 12's with a very stock looking/stock sounding engine. then later add heads and a bigger cam :D
  8. tannerc91gt Advanced Member
    Mar 29, 2009
    Message Count:
    3,933
    18
    68
    Indiana
    What are the specs for the cam?
  9. project67 New Member
    Feb 27, 2006
    Message Count:
    116
    with the correct cobra rockers (crane 1.7) it is .480 int and exh 118 deg lobe sep. and 270/270 adv. duration so pretty mild but a little more than stock ho cam. :rolleyes:
  10. tmoss Gettin Wired
    Jun 28, 2001
    Message Count:
    7,114
    78
    Saint Louis, MO
    The Cobra cam was designed to make more torque, not peak HP, in the intended rpm range.
  11. project67 New Member
    Feb 27, 2006
    Message Count:
    116
    so, should it compliment the stroker kit, or hold it back? down the road i will most likely go custom cam and some type of aftermarket heads.
Share This Page
