Car had 91,000 miles before the changes were made. Only 1,000 miles since changes. It is a rust free car from Missouri. Everything on the car is new, paint is Nissan Monterrey Blue. All the moldings and weather strips are new (door locks, handles, etc.). Battery relocated to trunk. Hood is a Cervini’s Cowl Induction. Exhaust: Headers are BBK 1 ¾ Long Tubes / X-Pipe / Flowmaster Mufflers.
MOTOR:-377cu 8.51 compression (1995 lightning block, dyno’d at 330 rear wheel horse power)/ Eagle H Beam Rods / Milodon 7 Qt Race Pan / Trick Flow High Port Heads & R Series Intake / 75 mm Throttle Body / 70 Pro-M Mass Air Meter / 30 lbs. Injectors / Vortech Fuel Rails / MSD Billet Distributor / MSD 6al Box / MSD Coil / Aluminum 4 Core Radiator / Flex Lite Fan / Electric Water Pump /Crane Gold Roller Rockers / Custom Group Cam / Adjustable Fuel Pressure Regulator
TRANSMISSION:
T56 6 Speed / Aluminum Flywheel / Center Force Dual Friction Clutch / Adjustable Pressure Plate / Aluminum Driveshaft
REAREND:
8.8 with 3.73 Motorsport Gears / Locker / 31 Spline 5 Lug Axles
BRAKES:
2003 Cobra Front and Rear / Stainless Brake Lines / New Hawk HP Plus Front Pads
SUSPENSION:
Front Suspension: Maximum Motorsports K Member / MM Caster and Camber Plates / MM Lower K-Member Brace / MM Front Control Arms / MM Tie Rod End Kit / MM Front Coil-Over Kit for Bilstein Strut / Spherical Washer Rack Bushings / MM Sway Bar End Links / Hypercoil Coil Over Springs 400lb/in / Bilstein Struts/ Flaming River Manual Steering Rack / Kenny Brown Sub Frame Connectors.
Rear Suspension: HP Motorsports Upper and Lower Control Arms / MM Rear Coil-Over Kit for Bilstein Shocks / Hypercoil Coil Over Springs 300 lb/in / Bilstein Shocks
WHEELS & TIRES:
10th Anniversary Cobra
245/45/17 BFG G Force (Less than 1,500 miles since new)
$13,000 (Not Interested in Trades)
Car is located in Elkhart Lake, WI. Call me at 303-772-1523
[email protected]
See photos at:
Pictures by 192cobra - Photobucket
TRANSMISSION:
REAREND:
BRAKES:
SUSPENSION:
WHEELS & TIRES:
[email protected]
See photos at:
